Letnje gume
E baš Vam thank you. a ja fan na real madrid  :Smiley:
Je li neko vozio Minervu?
Kod nas trenutno na akciji
Minerva f209  u dimenziji 205-55-R16 za 36 eura?
Razmisljam se da uzmem 4 komada sad za ljeto i 50 suvih stepeni, pa tamo u septembar opet da montiram zimske jer ove vjerovatno nisu neke za kisu?
Jelenko
#752
Posto sam se razocarao u kvalitet Tigar guma vrijeme je da trazim zamjenu.
Ima li ko iskustva sa Lassa gumama,proizvode se u Turskoj pa me zanima jel ko probao ove gume?
Jasho ih hvali, gazi ih treću ili četvrtu godinu bez problema. Tvrdi da ga dobro služe i ja mu verujem.
Goky
Iskoristite pogodnosti koje vam nudimo za kupovinu Motrio letnjih pneumatika. Ukoliko kupite tri Motrio letnja pneumatika, četvrti dobijate za 1 RSD
http://www.dacia.rs/akcije/otvorena-vrata.html
Fiat Punto Mk1 1.2 8v + TNG
VW Buba
DOT?
Minerva je medju poslednjima na ADAC testovima, cak iza Tigra.
#756
Citat: Jelenko poslato 16.03.2017. - 19:31
Za preporuku :to: pogotovo u poređenju sa Tigrom, ne troše se brzo, po kiši stabilne, ja imam Atractu, trebalo bi da je Greenways su još bolje, Brigestone je to, japanac :wave:
https://www.lassa.com/en-US/passenger-tyres
Jesu Brigestone taman toliko koliko su i Tigar Michelin.
Mnogi kupuju Lasu, kažu bučna u početku a kasnije  se manje čuje. Kao dok se skine neki prvi sloj...
#758
Turkey's tyre brand: Lassa
The foundations of Lassa, which has now celebrated its 41 st anniversary in the tyre business as Turkey's leading established brand, were laid back in 1974. Founded by the Sabancı Group of Companies and partners, Lassa was renamed Brisa ten years after starting production in 1978, after becoming a joint venture partner with Japanese giant Bridgestone Corporation,. Today Lassa tyre are produced with Brisa's latest technology and Research and Development studies.
Lassa is dedicated to top quality.
Lassa, in line with the needs of domestic and international markets, provides products which are approved by independent testing institutions, and whose quality has been certified with many awards. Lassa tyre earned the National Quality Award (1993) and European Quality Grand Prize (1996), and are produced with the concept of quality most suitable endure the roads in Turkey, and are approved by the German certifying institution TÜV SÜD. Lassa tyre are used in confidence by consumers only after reaching the marketplace after passing detailed safety tests.
Ja nemam problema sa njima imam pohvale, a kad Tigar Tyers budu sponzor Real Madrida možemo i na tu temu...
p.s.
Da pojasnim nešto, da ne ispada da sam drveni advokat Lasse, Nekad je i Tigar imao ime i kvalitet, što se posebno odnosi na Winteru koja je u svoje vreme kad je izašla bila sinonim za zimsku gumu, e tu zimsku gumu proizveli su inženjeri Tigra u svom razvojnom centru (R&D) e taj momenat razvoja košta i to je najskuplji segment svakog proizvoda i proizvođača. Da bi neko opstao na tržištu gde je R&D ključ uspeha, on maora da se razvija ili da propadne, u tom smislu ima nekoliko načina da se to reši, prvi je da sam kompanija ulaže svoja sredstva i ida se zadužuje da bi opstala na tržištu, drugi je da nađe gazdu i da se uklopi u njegove planove (slučaj Tigra, gde je Tigar postao low budget proizvod sa zastarelom tehnologijom iako to nije bio, primer kvaliteta prvih serija wintere i ove sad, pod kojom Michelin trpa istu gumu u tri ili četri brenda) i treći model je da uđe u kooperciju sa drugim proizvođačima (becoming a joint venture partner with Japanese giant Bridgestone Corporation) i pokuša da trošak R&D svede na minimum ida proizvodi kvalitetne gume sa pristupačnim cenama, e to ti je slučaj Lasse i Bridgstona. Zato ću uvek radije da kupim takav proizvod jer znam da dok god se bori samostalno na tržištu sa premium igračima, njegov proizvod nije drek kako bi Slovenci rekli! :wave:
Za Lassu narocito svezih testova velikih kuca (ADAC i sl.) nema, ostaje samo subjektivno misljenje korisnika. Jeste u korporaciji Bridgestone, ali nije Bridgestone. Kao sto je Sava u Goodyearu, ali nije Goodyear. Kao sto je Tigar u Michelinu, ali nije Michelin.
https://www.reifen-testberichte.info/adac-sommerreifen-test-2010/46/
http://www.autozeitung.de/reifen-test-zehn-sommerreifen-im-format-20555-r-16-v-19514.html?image=2
http://www.reifentest.com/pkw_sommerreifen/lassa/atracta/index.html
U svakom slucaju za prosecnog korisnika je dobra guma, kao i sve ostale. Neko kome je 5-10 metara zaustavnog puta bitno, morace dublje da zavuce ruku u dzep.
Nasao sam i jedan test gde se pominje Minerva, zauzima visoko 40. mesto, od 50 testiranih guma  :bonk:
Jasho, tvoj komentar je na mestu, preneo si svoje iskustvo i hvala ti na tome. Ja nisam imao nameru da se podsmevam i evo izvinjavam se ako je tako izgledalo.  :ziveli:
  Ja nisam kompleksas i ne pljujem po necemu sto je jeftino, da se razumemo. Winteru sam vozio na Loganu i nikada me nije izdala, cak sam je i vozio preko cele godine. Verovatno sam mnogo opreznije vozio nego sto bih sa nekom premijum gumom ali nisam vozio ni penzionerski.
Pred zimu sam kupio Wintere za Megana. E tu se vec prica menja, verovatno su u pitanju oko 400kg vise sa kojima su morale da se bore. Jos malo vise opreznosti, uz pomoc ABS, ASR i zavrsavaju poso. Za neki ozbiljniji auto, mislim na vecu tezinu i snagu ili sa zadnjom vucom (Merc, BMW), vec nisu. Verovatno je ista prica i sa letnjim gumama.
Pazi sad, sta bi covek pomislio gledajuci ovaj video? Marketing je cudo.
#761
Nema ljutiš :ziveli:
Ja u winteru sam imao poverenja, kad sam ih uzeo bile su ok prve dve godine, već posle je bilo pazi kako voziš! Vraćam se sad na letnje Siguru konkretno, imao sam ih na yugu, nakon tri meseca vožnje ili nekih 4000 km šara se prepolovila, trošile su se abnormalno, na mokrom znale su da proklizaju, sve u svemu najgora guma koju sam imao ikad! Prodao sam ih sa kolima. Mislim da u ovom trenutku na našem tržištu od ,,domaćih'' Cooper tyers ex-trayal je u ekspanziji, za kvalitet ne znam ali onako na dodir ne izgledaju loše! E sad se vraćam na Lassu, ako je razlika u ceni između Lasse i Tigra u 200-300 dinara, svako razmišljanje se tu završava, Lassa je za dva koplja ispred Tigra, i što je najbitnije što se tiče stabilnsoti, trošenja, kvaliteta u rangu je premimum brendova, možda ne Atracta, ali Greenways već jeste, Keka je kačio ocene za Atractu, ali nije za Greenways, pa pogledajte i sami http://www.tyrereviews.co.uk/Tyre/Lassa/Greenways.htm ili https://www.youtube.com/watch?v=q1a5LyomIfA
p.s. Što se tiče Lasse imajte u vidu da oni pre svega napadaju nemačko tržište tako su počeli, sad se već šire na čitavu Evropu, ali ko kod Nemaca prođe, mora za to da postoji dobar razlog...
Milan Ilić
U Planeti guma, ContiPremium Contact 5, 6.944 din + 490 montaža! Rekoše mi juče da je ova cena do kraja meseca a onda ide gore pa kome treba nek ne čeka...
shole
Po meni extra cena,ako nisu mnogo matore. Ja svoje GOODYEAR EFFICIENT GRIP compact platio 7300.
Milan Ilić
Nisu matore, DOT 0217. Zaboravio sam da napišem da je ovo cena za dimenziju 185/65 R15.
